1995 BMW 525i stock speakers
I would like to replace all the speakers in my 1995 BMW 525i. I have determined that the kickpanel and packagetray speakers are 5.25" with a 4" depth and that the dash speakers are 3". Can somebody please tell me where I can locate the two window frame speakers? No one even seems to acknowledge the existence of these. I'm assuming they're the high range tweeter.
if you are asking what is the size and mounting of the other set of speakers, i'd just remove one to verify.
the speaker sizes are odd enough to push you out of the realm of typical speaker choices. you didn't ask for recommendations, but i'll throw in my $.02.
for a 5" midbass recommendation - Tang Band W5-1685 Underhung 5" midbass driver
Tang Band W5-1685 5" Underhung Midbass Driver
for a 3" midrange/high recommendation - Daytom RS75-4 3" full range driver
Dayton Audio RS75-4 3" Reference Full-Range Driver 4 Ohm
if it were me, i'd add a crossover in the 200Hz range. you won't need a tweeter with these choices, but you can certainly add one for some extra information above, say, 8kHz.
pic of the inside:
http://img207.imageshack.us/img207/5973/img3490c.jpg
the tweeters in the sail panels are probably close to 3/4" or 5/8" replacing them will be a bit more difficult as you'll have to disassemble the factory mount and hope there is enough room for an aftermarket driver. or you can make your own mount.
a Dayton ND16FA-6 5/8" dome tweeter may fit. you'll have to disassemble it to know for sure what you can do.
denison831
denison831
Safety Harbor, FL
keep_hope_alive
