Sold 1991 Ford Escort GT
LuckyT
KY
1991 Ford Escort GT, 1.8L dohc engine with 55k miles on it. Rest of car has 160k miles on it. Automatic Transmission. Shocks/Struts and Springs replaced 3k ago. 2 tires have less than 1k on them and the other 2 have about 15k on them. Needs brake pads. Has some rust. Has been stored in my garage for the last couple years and hasnt seen much action. I have a new rear bumper cover and spoiler as well as clear corners for the front of it.
It is currently set up for 1 18" sub, but the baffle can be swapped out easily if you wanted to run 2 15's or 4 12's. With some work you could fit 2 18's. I have done a certified 157 db legal with 1 RE MT 18 and 1 Soundstream XXX-6500 amp and 12 16 volt turbostarts. It has done a 158.8 outlaw with the same setup. I have seen higher scores with more amps as well.
Vehicle comes with 2 alts, stock alt plus 300 amp HO alt and external regulator. Can run either 16 volt or 12 volt. Has 4 runs 0 awg power and 4 grounds. It is set up to run off the 300 amp alt only right now but has all wiring to change easily. Has a Odysee 2150 battery under the hood.
Has an Eclipse 55060 cd player that can be played from the dash or from a podium out back. Have the wiring installed for both. Has a set of Orion P5.2 components in the front doors and an Orion 8004 power them.
$650
Check link for pictures http://www.cardomain.com/ride/2685814
LuckyT
LuckyT
KY
LuckyT
