1986.5 hardbody base model????
I had that exact truck 16 years ago.
From what I remember, I had to wire everything up from scratch. No harness at all in the truck (again, from what I remember).
You have to cut the door panel, and can mount 6.5" speakers there. If you remove the door panel, you'll see exactly where you need to cut it, due to a hole in the door for a speaker to pass through.
where did you run your power wire 2 i tired going to fuse box but no luck
Freeman
I TrY
Freeman
Watertown, SD
Freeman
