180 amp alternator???
  • 4
Ull get good drop but ull be OK. That 180 is prob at 5krpms and is cold rated. Seeing as most ur driving will be below 3000rpm and once heated up you realistically have if lucky a 100a alt. Also, if ur amp is rated at 1700@ whatever load an is fused for 150-170a you will never actually draw that amount of amps as music is dynamic.
Will a 180 amp alternator the big 3 and a yellow top be able to handle an hdc3 15 sub running at 1700 watts??
That would soley depend upon the brand of the so called 180 amp alt. If it's a cheapo one, don't bother with it. Have read stories and people have bought HO alts before and they fail in matter of no time.
Just playing around. He's not even turning it up...
37
5K
165
395
  • Locked
702
High_flyerrr
High_flyerrr
Amite la
Boomin_tahoe
