18" Q with 8" Port in 7cu. ft. box tuned to 32Hz in Maxima... PICS
snb778
blaugh!!!!
Hey guys
This is just another build for the 18" Q in the Maxima
It is 7cu. ft., tuned to 32 hz. with an 8" Port blowing through the arm rest
It gets pretty loud, but not as loud as I was hoping for. It is just about the same as the last box I had, which was the 3x 4" Aeros at 5.6cu. ft. This one moves more air, or at least it feels like it, since the port is pretty much blowing right at me. Seems like it moves the change around in my cup holder a little bit more, and may get a TINY bit louder
Some resin I threw on all the corners and edges as usual
The Port
THe box completed
Installed in the trunk
Back of the trunk clearance
Left side clearance
Right side clearance
Power Setup
13" Long
please leave feedback
Here's the other box im comparing it to
Edit: no vids until my cousin comes home with his cam... dunno when that will be, or if i'll have this in there stil
as i stated... not much louder to the ear at least... probably a little higher on the mic though....
so basically i added 1.5cubes to the box, and have more port area I believe, and little to no difference.... ports on the other box fired towards the pass. side
The reason it doesn't sound any louder to you is probably the fact that the port and sub are both moving air thru that armrest. Seal off the port against the armrest, so that the box and sub are sealed into the trunk, and the port is sealed up against that armrest. Will sound better //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
morning bump!
so if you guys have any suggestions on how I can get louder, as far as setups go... drop em in here...
as of now, im going to sell the Q, and try to get an HDC18.... and use the old box, with a 10" port out the passenger side
snb778
blaugh!!!!
snb778
ex. Los Angeles, CA
snb778
