150dbzzz with this?
With that power i'd get something that was a bit more efficient for that power. Something like a DC LVL4xl would be really good with that power, granted it would laugh at it daily but still get loud.
Look in my sig, i only have 3500 or so watts going to a pair of 12" LVL4xls in a trunk car and am extremely close to a 150.
dude you guys are so clueless when it comes to power an subs. the lvl 4's are made for ground pounding that is why it don't take much power to move them. the hw on the other hand was intended for spl an some qround pounding i think. they need more power like the earliar poster said they do need more power. now the 3250 at .5 ohm load does about 3400 watts i think i am not for sure but i would check it out on rd site for sure an make **** sure you have the electrical system to feed that lil monster.
what size subs are using by the way. 12's 15's what. if 12's i think 10cubes is seriously toooooooooo big for 12's an about too big for 15's. i have seen guys put a 4 cube box in an suv an pop 150 with 3500 watts. but testin an testin an test would help fo sho.
dude you guys are so clueless when it comes to power an subs. the lvl 4's are made for ground pounding that is why it don't take much power to move them. the hw on the other hand was intended for spl an some qround pounding i think. they need more power like the earliar poster said they do need more power. now the 3250 at .5 ohm load does about 3400 watts i think i am not for sure but i would check it out on rd site for sure an make **** sure you have the electrical system to feed that lil monster. what size subs are using by the way. 12's 15's what. if 12's i think 10cubes is seriously toooooooooo big for 12's an about too big for 15's. i have seen guys put a 4 cube box in an suv an pop 150 with 3500 watts. but testin an testin an test would help fo sho.
18's im getting 1 more 3250.1 as soon as steve call's me next week i hope and im running the 1 i have at .5ohms now and tuned to 32hz and my tires flex as much as my windshild lol but i wonted to know about the tuning it to 36hz by cutting my port down for a comp sunday but im going to have to make my port 14" deep aposed to 21.5 and i dont wont port noise or hurt anything by doing it
her are the specs on the amp but @ 0.8ohms and i running mine at .5 so i dont know
The RD series amplifiers deliver a ton of power with a low distortion rate. We used the best parts we could find to give you a top quality amplifier that anyone would be proud to show off. With their clean looks and sleek finish, they’ll look good in any install. So whether it’s an elegant sound quality setup or a high powered SPL vehicle, the RD series amplifiers have you covered.
Features
Digital class-D linkable mono block amplifier
MOSFET PWM power supply
Daisy-chain through output RCA
Double sided through hole epoxy PCB
Stable into 1 ohm and 2 ohm parallel amplifier connection availability
24dB/oct variable crossover
Variable subsonic filter
Variable bass boost
Variable low pass filter
Variable phase shift
Efficiency : 86% @ 4 ohm, at 100Hz
Multi-way protection circuitry (Thermal/over current/speaker short/speaker dc protection)
RCA line input
Tested voltage & THD : 14.4V & less than 1% THD
Operating voltage : DC 10V~18V power input- 2008 models
Wired remote controller
MSRP
$1399.00
Specifications
RMS power, 2 ohm linkable/dual mono 5600w x 1ch
RMS power, 0.875 ohm mono 3750w x1ch
RMS power, 1 ohm mono 3000w x1ch
RMS power, 2 ohm mono 1500w x1ch
RMS power, 4 ohm mono 750w x1ch
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 300A(external type fuse - not included)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 222(W) x 52(H) x 590(L)mm
Click for product manual ››
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
dude its hard to tell, i mean i have seen guys do 50's at low freq. i heard of a guy doing it at 28 hertz not sure if its for real but i heard about it. logically higher tuning is for spl but with my setup its tuned high but it gets down an get the lows pretty **** good i think soo. i would say with 5600 watts an the subs you have i would say that its do able. but you really need to test cause if you can get a 149 out of it as is i can almost promise you its a 50 in it. sometimes its just the matter of finding it in your box or your vehicle.
ooooohhhh skip **** man cut the boi some slack man he just curious, but i thi nk i feel where ya coming from man, asking is not the way
TESTING TESTING TESTING TESTING TESTING TESTING AN MORE TESTING.
i think i have stressed that enought to him anyway, that your gonna have to try everything lol like i said you was doing low 50's with 4 10's so i know he can get close with the 18's, but your gonna have to test.
Too many variables to estimate a TL score on the sole basis of gear/equipment. Each vehicle has different transient responses in cabin just like a box. The highest numbers you see are all from trial and error. You can estimate a good daily sounding setup, but for strict SPL purposes, you've just gotta dive in and try shit until you get something that clicks.
mecaspl151
mecaspl151
sugervally
DNick454
