OK, I've been having a bastard of a time trying to fit a single ported 15 into this space. Just when I think I might be able to do it I try to get a port to work and it is either too long, too small(port noise), or it'd have to run behind the 15 and the magnet would be too close to the slot port wall....
I had my eye on an alpine type-r 15, which they recommend 1.5-3.0ft^3 ported, but through much discussion I've found that they want at LEAST 2.5 or higher, tuned really low, which creates the LONG port problem, which leads to not enough volume in the box for the 15.
Here's the mission should you choose to accept it......
33W x 17H x 14D external dimensions (really wanted 13"D but don't think it'll happen) These are maximum dimensions....
THANK YOU
THANK YOU
