1508 Enclosure
I came up with .62 ft^3 gross volume.
You will have even less once you subtract sub displacement.
Also the DD1508's will probably be too deep for your available space. I would look at some smaller shallow mount subs.
If I made 1-12” ported work You can do two 8”
That why I post the pics for you (with an Amp Rack too)
Just build it .
i know i can make two 8s work i was more concerned about the air space required for the DDs i really wanted to run those. what year ranger is yours? i also would like to keep all my factory trim like the rear speakers and panels, and what kind of ^3 are you getting?did you loose any cliks on the seat? i cant loose but maybe one click. how do you guys think one 1508 would do in that box given its deep enough and do they require sealed or ported
Edit:
Try the new SI BM.5 ft^3 enclosure requirement and only 3.5" deep
have you heard of a release date yet
I created this with paint so its not the best i will probably do wings off the side to give extra air space but u guys think this will work for two JL 8w3v3 and im not familer with the CA terms what is a F3(Hz) of 41 you may have to resize to really read it
bad03ranger
Get Some *****
bad03ranger
Reidsville, North Carolina, United States
bad03ranger
