Sold 15" TC Sounds TC5200 Quad 1.4
resko1
<<< 8" TC1000 LMS S3
Never thought i would do this but here goes.
Motor has usual tarnish common with TC motors. Top assembly is mint. powered only for ts parameters. Black basket, Titanium cone. I will supply a set of actual T/S parameters with the driver.
Just to let you know, this has an FS of 18hz and a BL of over 47tm!!!!
This is acclaimed to be one of the strongest motors available at about 420 newtons. Is probably one of the most capable sql subs ever. Rated a modest 2k rms 5k peak. I spoke with Thilo after my thread on the forum and he stated this is NOT the same cone as the snoopdan video on youtube. That was aluminum, this is titanium. Same cone material as the eclipse ti pro. They also put a deep dish to the cone to help with that issue. He said 5k is not a problem. I asked about 7k since i was going to acquire an atomic 7k and he said fine for short bursts. "Cone will hold, just dont bottom the coil". I dont think thats gonna happen:)
650 shipped. NO TRADES unless you have a SAZ3500d or SAZ4500d, then well talk a deal and i can add cash.
Motor will be crated then boxed, TC top will ship in original packaging.
**************I also have the ability to build another SPL top for this motor. Would be a 15" QCA'ed TI basket, silver. A D1 aluminum roundwound Bi-filar coil, 3.901id/4.22od/2.4ww. 4- stiff 9.75" spiders spaced, dual or triple sewn in leads, DD EROM cone assembly with fat high roll surround, and a 12" dished poly cap with color of your choice. Price is 200 extra.
And for those who dont know what bi-filar is, its where they use 2 leads of wire instead of 1 to wind the coil. In most cases, it can take double the power. I sent a pair to a guy for treo motors and he was burping 158's off a single 18 and 8-9k. Coil took it with no issues. I will try to post parts pictures tomorrow, if anyones interested.
looks kinda wimpy imo.....
Your joking right?
This is hands down the most badazz single sub i've ever owned. And i have owned 100's of subs. I must have smacked my head pretty good to wanna sell it and get sundown gear.
I will repeat this... "THIS IS NOT AN SPL DRIVER" Its not meant to be burped and if you bottom the coil out you will end up like snoopdan.
That is why i clearly posted box specs as 3-5cu @ 28hz so you dont go below box tuning too much. It will take 3-4k daily in the recommended box. And be the cleanest sounding, distortion free sql sub around.
I want this so bad, is there anyway you could get ahold of more?
No. Ive tried. You could probably have Thilo build one, but its going to be VERY expensive. Just for him to build a matching PR was about 700 bucks. The new reconed top alone is 850.
resko1
resko1
Sheboygan,WI
resko1
