Never thought i would do this but here goes.
15" TC Sounds TC5200 Quad 1.4
Motor has usual tarnish common with TC motors. Top assembly is mint. powered only for ts parameters. Black basket, Titanium cone. I will supply a set of actual T/S parameters with the driver.
Just to let you know, this has an FS of 18hz and a BL of over 47tm!!!!
This is acclaimed to be one of the strongest motors available at about 420 newtons. Is probably one of the most capable sql subs ever. Rated a modest 2k rms 5k peak. I spoke with Thilo after my thread on the forum and he stated this is NOT the same cone as the snoopdan video on youtube. That was aluminum, this is titanium. Same cone material as the eclipse ti pro. They also put a deep dish to the cone to help with that issue. He said 5k is not a problem. I asked about 7k since i was going to acquire an atomic 7k and he said fine for short bursts. "Cone will hold, just dont bottom the coil". I dont think thats gonna happen
650 shipped. NO TRADES unless you have a SAZ3500d or SAZ4500d, then well talk a deal and i can add cash.
Motor will be crated then boxed, TC top will ship in original packaging.
**************I also have the ability to build another SPL top for this motor. Would be a 15" QCA'ed TI basket, silver. A D1 aluminum roundwound Bi-filar coil, 3.901id/4.22od/2.4ww. 4- stiff 9.75" spiders spaced, dual or triple sewn in leads, DD EROM cone assembly with fat high roll surround, and a 12" dished poly cap with color of your choice. Price is 200 extra.
And for those who dont know what bi-filar is, its where they use 2 leads of wire instead of 1 to wind the coil. In most cases, it can take double the power. I sent a pair to a guy for treo motors and he was burping 158's off a single 18 and 8-9k. Coil took it with no issues. I will try to post parts pictures tomorrow, if anyones interested.
