15" sub, how much airspace?
  • 5
Jakee
19
Texas
alright guys thanks for all the help on the cvx 12 build, it worked out great! but i ended up putting a l7 kicker 10 in it. and it bangs! ill be uploading a video later.
i have a l7 15" kicker and i wanna know how many cubic feet of airspace i need and what hz i should tune it to, its a dual 4 ohm so ill be running it at 2 if that even matter.
thanks,
Jake.//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
He's telling you to use the search button. It should also be in the manual.
Pretty sure Kicker's website has specs for the sub as well. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
6.0 ft3 (170L) + port displacement
3.5 x 16.25” (8.9x41cm) port, 13.75” (35cm) long
Power Handling = 750W RMS
6 foot is a lil more than im looking for in my trunk lol.
would 5 be okay, or shud i just go to 6? and what hertz?
Thanks to every one who pitched in help, especially Ryan. cutting the pieces out now, 2 sides left, then only sanding and building to do. hopefully will get all build done tonight except for front and top.
Thanks guys.
love this fourm
224
550
581
Jakee
Jakee
Texas
Jakee
