15" nightshade
jshak07
148.4 and climbing
Gettin ready to start on a new build. Will consist of:
15" Sundown Nightshade D2
Alphasonik 1000HCA
All 1/0
Exide Orbital Deep Cycle
Damplifier Pro will be installed on all doors and on hatch and on the floor from the back seats back. I have more for rest of truck but probably wont have time to get it all on at first.
Will be going into
I want to be able to put up some good numbers on the TL so what kind of design you got for me? Should I do a slot port or aero? About what size box and tuned to what?
Thanks
are you hittin 148.8 with the 1 15"?
Yes. 1 Sundown NightShade 15" powered by a Sundown saz-1500d hitting 148.8s legal DbDrag style, sealed w/ the mic on the windshield. It'll do 150.5s outlaw/harcore style in the kick panel. It'll do 155s on the AudioControl meter at the Clash of Titans events. Yes, it's a daily setup that I also BassRace the 139.9 class with. Also in a direct swap to the prototype Sundown saz-2000d it hit a 149.5 legal.
jw but is yur 15" a stock nightshade?
max measurements are going to be 24" seat to hatch x 44" side to side x 20" floor up... 20" keeps me below the window line so I would like to keep it there if i can.. What should I do as far as layout? sub up, port up? sub back, port back?
Thanks
I'm thinking the best thing for you is a dual tune box. 3ft net volume with three 4" ports tuned to 42hz for spl then plug one port for daily which will be tuned to 34.5hz. The only problem I'm seeing off hand is your mounting depth. Let me do some calculations and sketchup something tonight.
jshak07
148.4 and climbing
jshak07
louisville
sundownz
