Originally posted by GrandAmGT Well I own 2 12" L7's...so I may be ablw to help you..
I run each L7 with 1000 watts, if not more. if you run 1000-1200 watts, you'd be great.
I ported mine, in a prefab, yes, prefab //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif giving each L7 1.9 cu bt, tuned at 35 hz, and metered at 148.6
if you port yours with, a ported box, tuned at 35 hz, but making it about 3 to 3.5 cu ft, you should be fine!...
my suggestion for an amp, just because I use a crossfire, you could get the Crossfire VR 1000. it's 1,000 watts at 2 ohms at 12 volts,.and when you run your car at 14.4 volts, you get a 15-20% increase in power..
there's my 2 cents, hoped it helps you! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
-Trenton
