$240 shipped obo
Fs: 25.9 Hz | 24.9 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 5.64 | 5.72
Qes: .54 | .54
Qts: .49 | .49
Mms: 257g | 279g
Cms: 0.15mm/N | 0.15mm/N
Sd: 810cm^2 | 810cm^2
Vas: 135 l | 135 l
Spl: 88.2dB 1W/1m | 87.7dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: 2-2.6 cuft
Ported box: 2.8-4 cuft @ 28-33Hz
Sub OD: 15.625”
Cut ID: 14.125”
Mounting depth: 8.500”
Displacement: 0.19cuft
$240 shipped obo
* 1,600 WATT Mono Block Class "D" Monster Subwoofer amplifier
* 1,600 x 1 RMS @ 1 ohm
* 1 ohm stable
* 1100 watts @ 2 ohms
* Mosfet power outputs
* RCA Outputs
* Advanced Class "D" Setup
* Built in all new BXI sound controls to control Bass EQ, Subsonic Filter, Low-Pass Xover & Phase Shift control
* All new efficient Heatsink Design
* Hifonics Logo Illuminates in bright neon blue illumination
* Power and Protection LED indicator
* Gold RCA Inputs with level control
* Built in advanced crossover system
* Balanced line inputs
* Soft Start Turn on for extra long lasting amplifier protection
* Subsonic bass filtration system
* RCA Line outputs for daisy chaining 2 amps together to run twice as much power
* Low Pass Filter: 35 - 250 Hz
* Requires 4 Gauge amp kit (available in our ebay store)
* Bass Boost: 0 - 18 dB
* Phase Shift: 0 - 180 degrees
* Amp stays cool with built in ventilation
* 24 dB Subsonic Filter (15 - 35 Hz)
* Dimensions: 13.77" L x 10.4" W x 2.63" H
Both were used for roughly 6 months. Amp comes with original box, manual, and remote bass controller.
