SOLD 15" Custom RE XXX, One and Only, Brand New, Never Seen Power $440
ramk1018
New York
320 plus shipping! CRAZYY
This is my 15" RE XXX motor on a custom, or should i say TWO custom baskets, with new softparts topped off with a CF dustcap. Its a monster, and weighs what a monster weighs too. It has never been installed, and the only time it has seen power was to test it out to get specs. You wont be dissapointed in the sub, but Im going with a multi woofer (10) setup, so I wont need this one.
*The decal on the cone is only a sticker and can be taken off easily. (its my last name for reference)
I WOULD LOVE TO KEEP THIS SUB, BUT I NEED AN AMP ASAP.
I have multiple feeback eBay, CA, CACO, and SMD: http://www.stevemeadedesigns.com/board/ind...amp;hl=ramk1018
Revc = 4.1835 ohms
> Rms= ~2500
> Fms = 37.2597 Hz
> Zmax = 61.9784 ohms
> Qes = 0.5934
> Qms = 8.1979
> Qts = 0.5534
> Le = 5.1174 mH (at 1 kHz)
> Diam = 330.2000 mm ( 13.0000 in )
> Sd =85633.5536 mm^2(132.7323 in^2)
> Vas = 83.2650 L ( 2.9405 ft^3)
> BL = 19.4102 N/A
> Mms = 228.2719 g
> Cms = 79.9300 uM/N
> Kms =12510.9395 N/M
> Rms = 6.5188 R mechanical
> Efficiency = 0.6820 %
> Sensitivity= 90.3558 dB @1W/1m
> Sensitivity= 93.1712 dB @2.83Vrms/1m
**Had to add more pictures //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
  • Locked
15" Custom Sub Dual 1 ohm I've had it running off 2000rms in my daily. I'll include the box if you're in SoCal for pick up, Dimensions are...
ramk1018
ramk1018
New York
ramk1018
