14.4v?
i was reading in a crutchfield magazine about that once the 12.9 or 14.4 volts it says that a amp with 12.9 will have better performance than a 14.4 i think most cars run at 14.4 on the gauge and the amp need those 14.4 for full performance and at nights like when u have other electrical things on in u car like headlights or u have ur a/c or rear defroster on, the gauge drps down a bit especially when ur stopped with engine on.
if anyone knows and read this i got the same doubt too cuz i have a 14.4 amp i just installed but i have not used my a/c yet or rear defroster thats when my volts drop to 14 or a bit less.//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
Ok, so what you're telling me is that I get 14.4 volts when the engine is running with lights, etc. off, and just 12 volts with engine off. But when i turn lights and other things on the voltage drops. Is this correct?
Thats why you always go bye the 12v rating. It is **** near impossible to get 14.4 volts to your amp in a car. MAYBE OFF A POWER SUPPLY, but not through car wiring. The most youll more then likely pull at idle is 13.8 volts. The resistance in the wiring itself will not allow a draw of 14.4 to make it to the amp. Even with stiffening caps and beefed up alts. MTX rates their 1500 watt beast at 14 volts, in actuallity youll maybe pull 1300 or so watts @ around 13.5 volts.
This really isn't that big of an issue.
Your car, given that it has a good battery and healthy alternator will provide about 13.6-13.8 (give or take) volts.
So say you have an amp rated (accurately) for 500 watts rms @ 14.4 volts. Well then, at 13.6 volts it would be
13.6/14.4 = approx 94%
500 x .94 = 472 rms at 13.6v you wouldn't be able to hear the difference
Then say at night with headlights and foglights on you drop to 13v.
That equals about 90% of 14.4 which would be 450 rms which still isn't likely to be noticed
In theory 14.4v is obviously what you want, but in reality, you're not going to hear a difference in a 1v change anyway.
if your having a hard time getting 14v then you have another problem....a bad alt. it should be easy to get at least 14.4v with the car running, i usually get between 14.9-15.1v at the amp.
Yes but it also depends on the battery wire you have running to the amp because if it's oo small than you will not get enough energy to the amp. this doesn't really matter unless you have an amp that puts out alot of power thus needing alot of energy to use.
when needing of more voltage to your amp off your batterie, add caps. they help a bunch. when i had 1 full farat, i was getting about 14.2 constant bright lights on ac running engine on, then i killed my alt. got a new one and got a 2nd cap. now i'm getting a steady 14.9 brights on a/c on engine running in park. so i'm happy but now my alt. needs to be rewound to put out more amps. new alt. or battery is an easy way to stiffen the amount of volts going to your amp.
keep it thumpin,
adam
ctaylor821
ctaylor821
USA
bumpin_blazer
