Sold 135ah C&D Batteries for sale = to HC3800...half the price.
RAM_Designs
SketchUp Master
100 pounds each, 134.8ah, threaded inserts for easy use of bolts/ring terminals. Resting voltage sits right at 12.8V and stays there for a very long time. It takes roughly 2500 watts for 15 straight minutes to drain one of these batts down to 10V(//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif). I have personally used these and gotten a better score over my HC2400's and Batcap 2000's...these actually have the same ah rating as a HC3800, which go for around $450 on ebay.
$180 each local, $250 shipped each, discount for multiples. Also, if you're buying more than one battery, I'm willing to drive a couple of hours to kill the shipping costs.
Detailed info: http://www.battery-usa.com/Catalog/ups12475.pdf
just curious how many do you have left?
If i was to use my D9 on these how many batts would suffice? Curious about gettin some from you, but unsure because of their weight... Its going in an Accord 1 RD D9 amp and 1 DD9515G and box so it will already weigh alot.
Any insight on how many would be good to use and how many would be too much weight wise?
I'm not sure how much the weight will be an issue, as I have no experience with accords. However, if I were to run a d9 with a stock alt in the 120-160 range, I'd get three of the batts. If you have a HO alt in the 200-250 amp range, then two batts should suffice. I have 4 left...
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
RAM_Designs
