Sold 135ah C&D Batteries for sale = to HC3800...half the price.
RAM_Designs
SketchUp Master
100 pounds each, 134.8ah, threaded inserts for easy use of bolts/ring terminals. Resting voltage sits right at 12.8V and stays there for a very long time. It takes roughly 2500 watts for 15 straight minutes to drain one of these batts down to 10V(//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif). I have personally used these and gotten a better score over my HC2400's and Batcap 2000's...these actually have the same ah rating as a HC3800, which go for around $450 on ebay.
$180 each local, $250 shipped each, discount for multiples. Also, if you're buying more than one battery, I'm willing to drive a couple of hours to kill the shipping costs.
Detailed info: http://www.battery-usa.com/Catalog/ups12475.pdf
This is a fairly big batt, I don't know if you could fit it in the place of the stock batt.
Bump for a hell of a batt.
They are rather big. I sold one to a superintendent on one of my jobs and he had to fab up a special bracket to fit it in his new model tahoe...it's the 11" height that makes it really hard to fit in an engine bay.
Any trades?
I really just need some power wire, but throw out what you have and I may bite...
if I put this in place of my stock battery, how many watts do you think my electrical will be able to handle without problems? I believe my alternator is rated at 90 amps.
Ouch, 90 amp is pretty small. You should be good for around ~1500 watts without much voltage drop. If you ran a Sundown 1500, or something along those lines, it'll get through your alternator pretty easy, but it'll hit a brick wall right around 12.8V once it gets to one of these batts.
u need to save some batts so u can finally get loud.
i will be there saturday how about u?
I'll hopefully be moving into my new apartment. I just got two of my Konaki motors in though, with a third on the way...building will start soon. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
edit: is that Jacko in the Spidey outfit?
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
RAM_Designs
