12inch Zv4 Rev2 Re-cone
  • 4
Idk if this is a stupid question but would this fit a 12zv3?
Edit. Nevermind. Found the answer. The spiders need to be changed. GLWS
Sent from my LG-H910 using Tapatalk
Idk if this is a stupid question but would this fit a 12zv3? Edit. Nevermind. Found the answer. The spiders need to be changed. GLWS
This is directly from Jacob...
While the v.3 motor has less excursion capacity than the v.4 it still has 47.5mm of clearance in it -- the v.4 has 62.5mm of clearance (bottomless... beyond what the coil allows).
47.5mm in no slouch... Jared has v.3 motors with v.4 parts right now in "The Beast" Jeep -- working well. It IS possible to bottom them out with the new suspension -- but it isn't going to just "accidentally" happen... as it's still nearly 4" p-p and that takes some juice to achieve.
As a safety measure we can down-size the spider to the next size down for a v.4 re-cone on a v.3 motor; we actually did that with Jareds... used a 9.25" instead of 10.125" spider on his 15s. The new frames support several different size spiders.
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Mayhem
Tiddies
Mayhem
Gainesville, VA
evilmonstertruk
audiobaun
    May 19, 2024
    May 19, 2024
