12inch Zv4 Rev2 Re-cone
Idk if this is a stupid question but would this fit a 12zv3? Edit. Nevermind. Found the answer. The spiders need to be changed. GLWS
Sent from my LG-H910 using Tapatalk
This is directly from Jacob...
While the v.3 motor has less excursion capacity than the v.4 it still has 47.5mm of clearance in it -- the v.4 has 62.5mm of clearance (bottomless... beyond what the coil allows).
47.5mm in no slouch... Jared has v.3 motors with v.4 parts right now in "The Beast" Jeep -- working well. It IS possible to bottom them out with the new suspension -- but it isn't going to just "accidentally" happen... as it's still nearly 4" p-p and that takes some juice to achieve.
As a safety measure we can down-size the spider to the next size down for a v.4 re-cone on a v.3 motor; we actually did that with Jareds... used a 9.25" instead of 10.125" spider on his 15s. The new frames support several different size spiders.
Mayhem
Tiddies
Mayhem
Gainesville, VA
evilmonstertruk
