1200.1 with 2 dual 2ohm speakers?
Your other options are a final nominal load of 8 Ohms (not wanted) or 1/2 of an Ohm which isn't particularly healthy for your amp.
Okay - the ZX1200.1 makes its biggest power @ 1 Ohm.
Now that we know this......with a pair of Dual 2 Ohm subs wired as above (since it is the only logical option) would give you 600w or 300w per sub.
With a pair of Dual 4 Ohm subs, however, wired parallel / parallel to make a 1 Ohm load you can get 1200w out of the amp or 600w per sub.
What subs are we talking about here?
Without knowing that I have no clue whether 300w or 600w into each one would be the better option...
ITS IN THE 1ST POST! i had an offer for a set of Kicker dual 2 ohm L7 12"s and my amp is a 1200.1
Settle down there, fella...
Let's review the 1st post, shall we?
i have a kicker 1200.1 amp and i need to run 2 dual 2ohm subs off of it how would i do that?
Hmm - I see that what kind of amp you're planning on using....but the only mention of the subs seen there is that they are Dual 2 Ohm voicecoil drivers ~ but not which brand or model.
As there are literally heaps of DVC 2 Ohm subs available you didn't give us much to go on there, didja??
'Tard...
Bagged96Chevy
Killer Kustoms
Bagged96Chevy
Texas
Prowler573
