what does spl do exactly?
1.) SPL is Sound Pressure Level. The more SPL, the "louder" it is.
2.) Because of the power handling and excusion capability, (and this example is very general and in theory) a single 12W7 given 1000w should or come very close to matching the out put of two 12w6 fed the same amount of power, provided both setups are in the same type enclosure.
Similar circumstances also dictate why a single 13W6v2 equals the out put of 2 12W3v's. The added area and power handling, linear excursion...things start to add up in a hurry.
3.) By many accounts from both users here and other forums and from magazine reviews, when pitting a W7 setup vs a W6 setup in an even matchup (I.E same power, 1 W7 vs 2 W6's, in the same type enclosure), most have said the SPL or loudness was very even, but that the W6 performed better in the sound reproduction department. Basically, the W6 was more musical, sounded better. This may be due to the W6's W cone being slightly different from the W7's W cone (look at both cross sections and you'll see what I'm talking about) or a bunch of different reasons. But I'm getting off topic a bit.
4.) Bottom line, if you can, get a listen for yourself and make the call. I have a single 13W6 on a 500/1, custom ported to JL specs, and not only sounds phenominal...but given my power level and just one sub...it gets pretty loud (for me.) I've had more than a few people not believe I oly have 500W and one sub until I popped the trunk.
Hope this was able to help some.
