12'' Resonant Engineering XXX sub, 2003
subzero
who knows what the specs are for this sub.
RE AUDIO - Woofers
Enclosure Recommendations
12" Compact Optimal
Sealed: 0.85 1.1
Ported: 1.7@35Hz 2.2@34Hz
T/S Parameters
12"
Electrical Q Value -Qes: 0.46
Mechanical Q Value -Qms: 3.29
Total Speaker Q Value -Qts: 0.404
Free Air Resonance -Fs: 21.00 Hz
Equivalent Compliance -Vas: 74.0 liters
One-Way, Linear Excursion -Xmax: 54 mm
Efficiency -SPL 1W/1m: 83.76 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 4.2 ohm
Nominal Impedance -Znom: Dual 2 or 4 ohm
Thermal Power Handling -Pe: 2000 W
Force Factor -Bl: 18.16
Product Dimensions
12"
Mounting Depth - 12.75 inch
Mounting Hole Diameter - 11.5 inch
Overall Diameter - 13 inch
Bolt Hole Circle - 12.25 inch
Motor Width - 10.5 inch
Motor Depth - 5 inch
Basket Depth - 7.75 inch
Displacement - 0.24 cu. ft.
Weight - 72 lbs.
subzero
subzero
Chandler, AZ
kingrukus
