12'' RD Sonace with Coil Rub
  • 4
cman0655555
1. Product:
12'' RD Sonace with FI Soft Parts. Has Coil Rub!
2. Specs:
Top quality audio equipment: Revolution Design Audio
[FONT=&amp]The V.2 is what we always wanted the Sonance to be, it has impeccable sound quality with solid output both in small ported and sealed enclosures. The V.2 has many upgrades over the original like a newly redesigned motor, taller stronger voice coil, Stiffer cone, and improved suspension to name only a few. The durability, sound quality, and output make the Sonance V.2 an all around champion of subwoofers in its class.[/FONT]
[FONT=&amp]Features[/FONT]
  • [FONT=&amp]Available in 8/10/12/15/18” models[/FONT]
  • [FONT=&amp]500/1000 watts RMS power handling[/FONT]
  • [FONT=&amp]Dual four ohm [/FONT]
  • [FONT=&amp]Available in dual 2 ohm flat wind with additional cost[/FONT]
  • [FONT=&amp]Pure custom SPL version available[/FONT]
  • [FONT=&amp]Three layer durable foam surround[/FONT]
  • [FONT=&amp]Dual stacked high power magnets[/FONT]
  • [FONT=&amp]Hot forged 25mm tall t-yoke[/FONT]
  • [FONT=&amp]High excursion motor[/FONT]
  • [FONT=&amp]Cast basket[/FONT]
  • [FONT=&amp]Poly/cotton spider bolted to the basket[/FONT]
  • [FONT=&amp]High temp glues used[/FONT]
  • [FONT=&amp]Black anodized aluminum former[/FONT]
  • [FONT=&amp]2.5” diameter voice coil[/FONT]
  • [FONT=&amp]Ridged paper cone with Kevlar fibers[/FONT]
[FONT=&amp]Specifications[/FONT]
[FONT=&amp]12" D4[/FONT]
[FONT=&amp]FS[/FONT]
[FONT=&amp]29.9 HZ[/FONT]
[FONT=&amp]RE[/FONT]
[FONT=&amp]7.2 OHM[/FONT]
[FONT=&amp]QMS[/FONT]
[FONT=&amp]5.8[/FONT]
[FONT=&amp]QES[/FONT]
[FONT=&amp]0.494[/FONT]
[FONT=&amp]QTS[/FONT]
[FONT=&amp]0.455[/FONT]
[FONT=&amp]RMS[/FONT]
[FONT=&amp]8.93[/FONT]
[FONT=&amp]CMS[/FONT]
[FONT=&amp]0.099 MM/N[/FONT]
[FONT=&amp]MMS[/FONT]
[FONT=&amp]265.7 G[/FONT]
[FONT=&amp]BL[/FONT]
[FONT=&amp]27.5 TM[/FONT]
[FONT=&amp]SPL@1W[/FONT]
[FONT=&amp]87 DB[/FONT]
[FONT=&amp]VAS[/FONT]
[FONT=&amp]42.8 L[/FONT]
[FONT=&amp]XMAX[/FONT]
[FONT=&amp]19 MM[/FONT]
[FONT=&amp]XCOIL[/FONT]
[FONT=&amp]52 MM[/FONT]
3. Description/Condition:
The sub does function but has coil rub that is audible. I wouldnt reccomend running it as is. It will need a recone! You can get them directly from rd, fi, and im sure psi as well. Last time I checked the fi recone was around $60-70. Your getting a nice motor with a good basket.
4. Price: : $60 obo+actual shipping and paypal fees. If your local we can just meet up or I will drive to you for a small fee. Shouldn't cost to much to ship as it doesn't weigh that much. Not really looking for trades but doesn't hurt to ask.
6. Pictures:
1. Product:
12'' RD Sonace motor only
2. Specs:
Selling motor only. Motor is 100% functional. Has a clean gap just needs a basket and recone. You can get them directly from rd, fi, and im sure psi as well. Last time I checked the fi recone was around $60-70.
4. Price: : $40 shipped anywhere in the continental US. If your local we can meet up or I will drive to you for a small fee.
6. Pictures:
Here is an updated version of this thread being I can edit the original 1st post. BUMP
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
680
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
3K
Okay i found one under b stock on alphards shop site but unable to actually place order grrr
3K
cman0655555
cman0655555
Carlisle, KY
cman0655555
Decebal
    Jun 10, 2024
