12" TC Sounds/ESA TC9+ LMS custom
I used this in my HT setup for awhile. Gets LOW in a sealed box. TC9+ motor with copper shorting ring from an Eclipse sw8000, 12" Axis basket, single med 10" spider with sewn in flat leads, S3 ohm aluminum roundwound LMS coil, DD erom cone assembly and full cover poly cap with a slight texture and dome. Rated 800-1000 rms. Ideal box would be 2-3cu sealed. Its whole life its only been powered by 300w. About 6mo old for rebuild. In the last pic i used a piece of tape on the cap to show you how much it moves. About a good 3" p to p. And makes absolutely no mechanical noise till after xmax.
Here are actual tsp's.
ESA Axis tc9lms
FS-26.24hz
QTS-.7175
QES-.846
QMS-4.724
VAS-2.647cuft
RE-2.771 ohms
Zmax-18.24 ohms!!!!!!
LE-1.32mH
CMS-.2mm/N
MMS-186.1g
BL-10.02tm
SPL-83.94db 1w/1m
240 shipped conus
ESA Axis tc9lms
FS-26.24hz
QTS-.7175
QES-.846
QMS-4.724
VAS-2.647cuft
RE-2.771 ohms
LE-1.32mH
CMS-.2mm/N
MMS-186.1g
BL-10.02tm
SPL-83.94db 1w/1m
240 shipped conus
