12" TC9 D2
This is in gorgeous used condition, suspension is still stiff. This is one of the rarest versions of a TC9, made for Entasi Audio. Loves, loves, loves tiny sealed enclosures. Model it, you will see it's less than .75 cu.ft for a Qtc of .7 with extension as far down as you wish once transfer function and EQ are factored in. Will also get down in a 2 cu.ft vented enclosure tuned however you like it. Doesn't need much power but it will absorb it. 800 to 1200w would be perfect in most scenarios. This TC9 has 1" slugs.
T/S Parameters
Qts - .313
Qes - .349
Qms - 3.00
FS - 24hz
Vas 73.32 l
Mms - 201.9
Cms - 216.6
Bl - 17.93
SPL - 86.49
X-max 24mm
Dual 2-ohm VC
Sd – 489 cm^2
$275 shipped, CONUS.
CONUS only, please.
12" TC9 D2
T/S Parameters
Qts - .313
Qes - .349
Qms - 3.00
FS - 24hz
Vas 73.32 l
Mms - 201.9
Cms - 216.6
Bl - 17.93
SPL - 86.49
X-max 24mm
Dual 2-ohm VC
Sd – 489 cm^2
CONUS only, please.
