12" l7 with video
anyone how do i set my ssf and what hz test tone should i use
also do i set my ssf first then my gain or gain first
I set gains with a 35hz 0db tone, but anything in the amp's range
IMO the best way to set ssf is by ear/eye I use it to limit the sub's excursion....ATM i do not have one set, as my box is tuned @24hz
so 70hz is fine setting the gains
and i set the ssf after setting gains to limit the excursion mine is 20-50hz what should i set the ssf to around 30 right around halfway
so i should set at 30hz and use a 70hz -3db test tone since i listen to rap right
and my volts on the dmm should read 27.3 for 750watts at 1ohm so if i do 27.8-28 thats fine as well since the sub wont always see the true 750-800watts
king ranch
Banned
king ranch
fl
king ranch
