12" Kicker Comps
//content.invisioncic.com/y282845/emoticons/search.gif.e79a63b2b580b39b282dff402646b704.gif jus serch man this topic has been discussed so many times, but anyways whats ur pice range?
well it kind of depends on which model you have if you have the comps or the compVR's if you have the comps i would go with a 2 channel amp or with an amp putting out about 300-400 and 2 ohms. if its the compVR depending on the coil config. i would probably go with an amp that is 1 ohm stable that puts out a pretty good amount of power probably hifonics or someone like that
Xtrmaudio- he just said... kicker comps... he didn't add VR... It would be annoying as whatever to go around saying "i have kicker comps, and no not the VR's"
I'm assuming they are dual 4ohm subs, which means you can either bridge a 2 channel amp or have a 1ohm mono amp(preferred). What's ur price range?
look at profile on ike sound, or on http://www.profileusa.com (their homesite) and u can get factory refurbs for hella cheap
I got a Profile AP1200 for my 2 03C124 comps. under $120 shipped new not refurbed from millionbuy on ebay its more than the speakers need but why push the amp if you dont have to //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Peak Output Power (4 Ohms): 400W x 2
RMS Output Power (4 Ohms): 200W x 2
Peak Output Power (2 Ohms): 600W x 2
RMS Output Power (2 Ohms): 300W x 2
Bridged RMS Output Power (4 Ohms): 600W x 1
peterson703
peterson703
Flemingsburg, Ky
denim
