12" fi BL: Memphis 16-mc1000d or DLS Ultimate A6
spark plugs.
i currently have this amp:
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2990
Product Description:
1100W RMS Class-D Monoblock Subwoofer Amplifier
Custom Black Pearl Finish
Fully Variable Low-Pass Filter: 50 - 250 Hz, 18 dB/Oct
Variable Subsonic Filter: 20 - 50 Hz
Bass Boost: 0 - 18 dB
Gold-Plated RCA Connectors
4 Gauge Power Wire Capability
Wired Remote Gain Control
Power and Protection LEDs
Thermal, Short Circuit, and Overload Protection
RCA Outputs: 1 Pair
Adjustable Input Level Control: 400 mV - 4V
Damping Factor: 300
DImensions: 13.4" L x 6.25" W x 1.7" H
1-year Sonic Electronix warranty
Amplifier Specifications:
Amplifier Class N/A
Number of Channels 1 - Mono
RMS Power (4 ohms) 300 watts x 1 channel
RMS Power (2 ohms) 600 watts x 1 channel
RMS Power (1 ohm) 1100 watts x 1 channel
Bridged RMS Power Not Bridgeable
Peak Power Output 2200 watts
Minimum Impedance Unbridged 1 ohm
Minimum Impedance Bridged Not Bridgeable ohms
THD at Rated RMS Power 0.75%
Speaker Level Inputs No
Preamp Outputs Yes - 1 pair
Built-in Crossover LPF(50 - 250 Hz), Subsonic(20 - 50 Hz)
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency N/A
Subsonic Filter N/A
Signal-to-Noise Ratio 95 dB
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote N/A
Fan Cooled N/A
Fuse Rating 40 A x 2
but someone i know is willing to pay me an excellent price for that amp and i'm considering getting a DLS Ultimate A6.
Product Features
RMS output per channel at 13,8 volts,
Mode : AB
Number of channels : 1 (for subwoofer use)
Output power in 4 ohm : 500 W
Output power in 2 ohm : 870 W
Output power in 1 ohm : 1200 W
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,2 - 7 V
Filters : Lowpass: 50-125 Hz. Subsonic: 25 Hz
Terminal for external cooling fan : Yes
Dual DC-inputs : Yes
Phase control 0-180 degrees : Yes
Remote sub level control with phase shift : Yes
Current draw, idle : 0,6 A
Current draw, maximum : 140 A
Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Product Description
ULTIMATE series A6. A 1 ohm stable monoblock that´s perfect for SPL. Extremely powerful power supply. The output power in 4 ohms are 500 thrue RMS watts. A cooling fan is built in but the amplifier also provides a built-in fan control for external cooling fan.
Built-in, variable 50-125 Hz low-pass filter for subwoofers plus a 25 Hz subsonic filter with an 18 dB/octave slope. Dual power terminals where you can connect dual power feeds or a DLS Power Cap. Extra features are a phase control variable 0-180 degrees continiously.
A remote sub level control is included. Adjust the sub level and phase from the front seat!
Heavy-duty capacitors act as a buffer zone between your amp and your car's electrical system. They store up a reservoir of power, which can supply the amplifier's peak demands (like a kick drum beat) without having to get additional current from the battery. All amplifiers have built-in capacitors, though high-performance amps use larger, more effective ones. External capacitors connect to the power cable just before it reaches your amplifier.
Also called an infrasonic filter, a subsonic filter cuts off extremely low bass (below the range of human hearing) that many speakers cannot effectively reproduce, thereby making the amp's power supply and output devices, and the speaker, more efficient.
The amount of continuous power, measured in watts, that an amplifier produces is called RMS power. The higher the RMS figure, the louder and cleaner your music sounds. When choosing an amplifier, the RMS rating is the power rating you should pay most attention to.
The unit of measurement for impedance or resistance. It tells you how much a device will resist the flow of current. If you take two signals of exactly the same strength and send one to a 4-ohm speaker and the other to an 8-ohm speaker, twice as much current will flow through the 4-ohm speaker. In other words, the 8-ohm speaker will require twice as much power (wattage) to play at the same volume.
is this is a good idea? will there be any difference switching from a class d amplifier to a class ab?
Link doesn't work :\
Class a/b amps are noticeably less efficient (10-25% lower in most cases) but are still good. If you fix the link, it would be easier to help you //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
DLS Ultimate A6 1200w Specs :
# Nominal power in 4 ohm: 500 W
# Nominal power in 2 ohm: 870 W
# Nominal power in 1 ohm: 1200 W
Memphis 16-MCD1000 (guessing this is the amp you meant?)
* 300 watts x 1 chan. @ 4 ohms
* 600 watts x 1 chan. @ 2 ohms
* 1100 watts x 1 chan. @ 1 ohm
Assuming these do rated power, I'd go for the DLS if you want it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Other than a loss of efficiency, it's a pretty similar amp. Also, class a/b's have an arguably better SQ, although this is very debatable :p
i actually have the 16-mc1000d, it's the older version. it's smaller and neater, but i don't know what improvements are made on the newer one.
yea get something with 1500+ watts.
1kw is not nearly enough to get bl's moving. i know there rated for 1kw, but honestly i wasnt happy with 1.4kw a piece. the suspension is too stiff, and needs some real power to get them moving.
Stick with the memphis for several reasons.
1)you wont hear a differnce in the distortion or sound that someone mentioned between the class D and A/B Not on a subwoofer for sure.
2)the memphis will have less current draw for the same amount of power
3)they are of the same build quality
4)you already have a great amp
5)you dont need 1.4kw on a sub that is for one rated at 1k for 2 you just dont need 1.4kw daily IMO.
I own the an older MCD1000, its the same board. They did do a couple of adjustments from what I hear to them to make rated power at a lower THD. Mine is rated at 1.5% THD at 1100 RMS. New ones are 1% I think. Either way still not audible.
spark plugs.
spark plugs.
New York, NY
spark plugs.
