12’’ Sundown Audio Nightshade v1 with Aluminum Pole Plug
cman0655555
Nightshade 12" Subwoofer
If you want a loud subwoofer to use both daily and in the SPL lanes then look no further than the Sundown Audio Nightshade. Many Sundown Audio customers are already using Nightshade woofers to achieve SPL levels in excess of 150 dB on music in their vehicles! *
The Nightshades feature strong paper composite cones with an additional stiffening disc located behind the thick poly dust caps. The tinsel leads are tied down to the spiders so you never have to worry about the leads slapping or popping against the cone and spider at high excursion levels!
The Nightshade woofers are assembled in the USA with only the best high strength adhesives and materials.
* Please use caution as excessive SPL levels such as those achievable with the Nightshade subwoofer can cause permanent hearing damage!
FEATURES AND SPECIFICATIONS:
• Dual 2-ohm or Dual 1-ohm Voice Coils Available
• 3" Diameter 8-layer flat-wound Aluminum Wire Coil
• High Temperature Aluminum Voice Coil Former
• 1500-Watts RMS Power Handling
• Over 2 inches peak to peak excursion
• Wide, triple-layer foam surrounds for high excursion
• Extremely strong paper cones w/ stiffening disc
• Thick poly dust caps
• Cast Aluminum 12-spoke basket with cooling vents
• Triple Stacked 1" x 9" magnet slugs for high motor strength
• MSRP - $629 USD T/S D1 **:
RMS: 1500
Z: 2 ohms
Re: 1.44 ohms
Fs: 43 Hz
Qms: 6.83
Qes: 0.43
Qts: 0.40
VAS: 11.7 L
BL: 17.6 NA T/S D2 **:
RMS: 1500
Z: 4 ohms
Re: 2.9 ohms
Fs: 41 Hz
Qms: 9.36
Qes: 0.46
Qts: 0.44
VAS: 11.7 L
BL: 22.8 NA
** T/S Specifications measured with coils in series
Enclosure Suggestions :
1.5 - 2.25 ft^3 Ported Tuned to 30-40 Hz
DO NOT USE A SEALED BOX
Mounting Specifications :
Mounting Depth = 8.25"
Overall OD with Gasket = 12.5"
Cut-Out Diameter = 10 15/16"
Sub Displacement = 0.18 ft^3
10/10 function
7/10 cosmetic
Was bought directly from sundown and I am the only owner. It is a refurbished motor so its not perfect cosmetically but nothing is physically wrong with it. It does have a few nicks in the surround from where it was taken in and out of boxes for spl tesing. Will come with a gasket although there isn’t one in the pictures. I wanted to show the blemishes so you know what you are getting. Also the basket has been painted and there are a few chips in the black paint. Once again nothing that would hinder the performance. Ive tried to get pictures of all the imperfections but if there is something you want to see in more detail let me know and I will get it. I took the pics with my phone but can get better pictures with my camera if desired. The sub was never abused and honestly I don’t beat on it hard daily at all, only time it was pushed hard was during competition. The only power this thing has seen is my single sundown 1500@1ohm. I measured the true rms power I was getting out of my setup and it was 600-700 watts. It never got stinky and as you can see in the pics the coil is perfect till this day. The only reason for selling is that I am looking to downgrade to something smaller that weighs less and will suit me better for my daily needs. I am calling it quits on competing for now so I don’t need this type of sub.
225+actual shipping obo. If local would be willing to meet up for cheaper. Also willing to meet halfway if less than a few hours of travel or bring it to you for a small fee.
Only trades I am looking for is a 10’’ or 12’’ FI Q, Sundown Z Series or similar SQL style sub
Dual 2 only. No 15s or 18s have no use and can’t fit them.
Will ship fedex or usps your choice. To many subs broken by our local ups site. If local would be willing to meet up for cheaper. Also willing to meet halfway if less than a few hours of travel or bring it to you for a small fee.
LOL 1500 rms... GLWS sir.
If you reconed this with a copper coil it would make a decent SQ sub, Zs are a nightshade motor with a copper shorting ring and a copper coil
then why does the z have a double stacked and nightshade has a triple stacked motor? jacob has came online several times to show the differences between the 2 woofers. and this woofer laughs at 1500w, i will be putting a 15 nightshade on about 2700w here very soon
your just jelly i got it before you did //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
didnt want it but coulda got it if i wanted it thomas my girl homie //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
well thomas is my bitch dawg //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
and i aint no groupie, and you know i shouldve won the more mexican poll on FB between us.
cman0655555
cman0655555
Carlisle, KY
cman0655555
