D DeKaL44 10+ year member Member 44 0 OH Aug 30, 2002 #1 if the amp's frequency response is 20hz to 500hz and the subs frequency response is 20hz to 1500hz does that mean that the sub will only play from 20 to 500 b/c of the amp or not???? thanks Click to read more...
bigbassman Premium Member Master of all things loud 3,082 2 Southern WV Aug 31, 2002 #2 the woofer can only play whatever the signal is giving it... if 500hz is the limit of the amp, that is all the woofer will have.. *note, most woofers have a ton of breakup above 150hz, so running them that high, isn't advised* Loyd L.
