1000w RMS at 4 ohms for only $130 Shipped
cthedinger
CT Sounds T-300.2
https://www.ctsounds.com/products/t-300-2
Brand New in Box
Order here:
AMPLIFIER RATINGS:
2Ω @ 14.4V Stereo, 470W (RMS) | 940W (MAX) x 2-Channels
4Ω @ 14.4V Stereo, 300W (RMS) | 600W (MAX) x 2-Channels
4Ω @ 14.4V Bridged, 940W (RMS) | 1880W (MAX) x 1-Channel
TECHNICAL SPECIFICATIONS:
No of channel: 2
Frequency response (-3dB): 10Hz ~ 50kHz
Gain adjustment: 0.2v ~ 5v
Channel separation: 50dB
Bass boost: 0dB ~ +12dB
Signal to noise ratio: 100dB
Damping factor: 150
Minimum speaker impedance: 2Ω (Ohms)
Wire input: 0GA
Low pass filter: 40Hz ~ 4kHz
High pass filter: 15Hz ~ 4kHz
Operating voltage (-ve ground): DC 14.4v
DIMENSIONS:
181mm (W) x 55mm (H) x 540mm (L)
$129.99 with free shipping
Free Shipping
Order here:
Another alibaba special. Yay
//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
distributed by a company with a disrespectful owner just in it for a quick buck, win win!
CT Sounds 7k, nevar forget
you know, why put bolts in to secure the board in the bolt holes made just for it? Just blame the customer in EVERY situation because your ego is too big! Pretty fucked that you filed a frivolous complaint against someone showing the reality of the board
Sean at EMF audio is going down the same path (although his problem is only ego atm)
This may be a good board at a good price, but I'll never forget that lack of professionalism showed by Coleman //content.invisioncic.com/y282845/emoticons/waycrazy.gif.f4a380c3f94043939fd369defd9e6be2.gif
@cthedinger i was looking around found some information that you stiffed a buildhouse a quarter million dollars, that's a **** ton of money
is this just one of those "simple mistakes" you made?
I vote the single 12. It is plug and play, looks nicer, more powerful, and takes up less room. If you decide to get a custom box for it, you sell...
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
883
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
No issues there. The amp will output depending on the speaker's impedance rating. Are you using a component x-over or is only the tweeter with x-over?
904
cthedinger
cthedinger
Inglewood, CA
sersentra
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
