1000 Watt Amp At 1 Ohm ?
DJSlowfets
5
CA
Looking for anything under $200
My only concern is im stock electrical so ive been searching for bigger amps so I have overhead but thats where you get into real money im not looking for a miracle but if you guys have any suggestions on an amp you KNOW will do 1000wrms @ 1 ohm on stock electrical ( No extra battery as of now, saving for that) with 105 amp alt let me know! Thanks
Been looking at this any thoughts ?
Precision Power PPI BA2600.1D 2600W Class D Car Amplifier
That just wouldn't work for me sorry. That's at 14.4 what I need I'd maybe see 700 out of that amp and that quite a bit more than the one I have linked for less. If you get any more PPI products let me know I know you're a small business I'd love to help out //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I've clamped mine at 1,100 ish with a 130 amp alt, and the big 3. I was getting voltage drop in the low 12 s though. I like the amp alot. I think a Ph4000md will burn up you alt. Plus the v drop will be bad for the amp.
Looking for anything under $200 My only concern is im stock electrical so ive been searching for bigger amps so I have overhead but thats where you get into real money im not looking for a miracle but if you guys have any suggestions on an amp you KNOW will do 1000wrms @ 1 ohm on stock electrical ( No extra battery as of now, saving for that) with 105 amp alt let me know! Thanks
here you go $209 shipped with warranty, will do about 17-1800 clean just dont go crazy on the gain and will give you some extra if you ever wanted alittle bit more.....
I have the 3k currently and its a def a solid budget amp forsure. Running at .5ohms daily with stock 80-90a alt and a couple batts, with 1/0 wire, and 1/0 big 3. Voltage holds about 12.3v(12.0v depending on song)at full tilt which i rarely run full, usually around 1/2 power when riding so voltage stays around 13v and i will say its not a power hog at all to me it seems and doesnt get to hot. I got it when they were cheaper(250) now they are 350-400 new for the 3ks.
Soundstream Ta1.2000d - $209 with warranty Rated 2000rms @ 1 ohm(actually does about 1700-1800 rms VIA clamp tests) just turn the gain down some.
Soundstream TA1.2000D 1 Channels Tarantula Amplifier at Onlinecarstereo.com
DJSlowfets
DJSlowfets
CA
bgowdy
