1000/1 & 2 W6's working but no BUMP
Cshread
I just got done hooking up my new system consisting of a JL 1000/1 and 2 12" W6v2 subs. I also just got a brand new optima red top. All the power lights are on and working correctly, and the subs can be heard and are semi loud when gains are cranked, obviously somethings wrong. Even when cranked these dont sound near as loud as my W3's. So im thinking its some setting on the 1000/1 one but i dont know which, any help please, i need to hear these bump! here are my settings:
Out Mode: FullRange
Filter Slope: 12dB
Filter Frequency: 65Hz
Filter Mode: LP
Infrasonic Filter: On
Infrasonic Freq.: 30Hz
Bass EQ: Off
Q: 1.4
Center Freq: 45
Bass Boost: 0
Mode/Slope: 12dB
Filter Freq.: 65Hz
Input Voltage: Low
Input Sensitivity: About 11'O Clock, maybe 35% of the way
Then my RCAs are plugged in here in the Amp Input
Output Polarity: Normal
1)Cross them over higher then 65hz
2)Is the box ported or sealed?
3)Turn the gain up-not that it's a direct comparison, but the gain is all the way up on my 1000/1 (no bass boost etc).
They are wired parallel, the positive and negative from each terminal is connected to each of the subwoofer outputs, im not sure the preamp voltage on my deck, ive had the same Alpine for like 6 years, anyway of know how to check?
Set gains with volume to about 3/4 generally speaking. Also, your subsonic needs to be around 15-20 preferably. And yes, your LPF needs to be at like 80 Hz or so, NOT 65, that's cutting out a lot of octaves.. you're sub is only playing between 30-65 Hz! That's a very small freq. range.
Cshread
Cshread
Austin, TX
Turbo Travis
