*SlappinAzz*
Shoot em
too much trouble for a peice of shit amp.maybe the crossover circuitry can be bypassed
and it is class D topology which while it can play higher frequency if you could bypass the x-over, it would sound horrible...maybe the crossover circuitry can be bypassed
it may could be usefull as a midbass anp or even up to midrange freqs so as a rear fill amp it could be useful if circuit was bypassedand it is class D topology which while it can play higher frequency if you could bypass the x-over, it would sound horrible...
class G or X or T or even a DG or XT hybrid would work but if it was that easy everyone would use D class topology for all amps..
Im aware. Its not any different than any other OEM amp.they are class D.... mono only... and a fixed 150Hz low pass that is not adjustable...
well worth it for something like that //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifThis may be useful for midbass like four 5 1/4" 4 ohm woofers wired to 1 ohm per door then filtered between 55Hz to 150Hz.
