10" dcon box specs
  • 4
as the title reads.... what are the recommended box specs for a single 10" dcon ported?
do you mean GCON? because that is what you won //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Sealed .50-1.00ft^3
Sealed Optimal 1.0-1.25ft^3
Ported 1.00-1.50ft^3 @ 28-33hz
Ported Optimal 1.75-2.00ft^3 @ 28-33hz
Sub Outside Diameter 11.000"
Cut Inside Diameter 9.250"
Mounting depth 6.500"
it was a long day when i posted this.... yes GCON i meant.
No problem //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Are you able to squeeze anymore volume out of the space you have available? What kind of power are you going to have going to the woofer? The 4" port is on the small size. If you are running close to rated power you will probably have some port noise. I would opt for a slot port design.
i can go bigger. when i came up with those specs it was based off the dcon(forgot i was getting a gcon lol). i was thinking of bumping it up alittle to maybe closer to the 1.5 cubes ported. i would do a slot port but dont have the ability to do a 45 cut to get the inside corner piece for the port. i couldnt imagine doing a 5" port. the plans are to do sub facing up behind the driver seat and port out the passenger side. the face of the box(where sub is) will be glassed. got a new router so want to try a few things but keep it simple so it goes quick for the build, plus want to try my hand using my compressor to lay some paint down on the box since i have a bigger project coming after this small build.
feel like i just rambled lol
? What kind of power are you going to have going to the woofer? If you are running close to rated power you will probably have some port noise. I would opt for a slot port design.
i will be running these off a cadence momentum 5000.1 amp that does 1200.1 @ 1 ohm which i plan to wire the D2 sub down to.
got my amp in.... should start this build this weekend. hopefully it goes pretty quick. rated to awake this gcon.
Post install pix. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
redrider
redrider
jacksonville, fl
redrider
    Apr 28, 2024
    Apr 28, 2024
