redrider
as the title reads.... what are the recommended box specs for a single 10" dcon ported?
Scroll down and click on enclosure recommendations. DCON Series Sub Wooferas the title reads.... what are the recommended box specs for a single 10" dcon ported?
Should work great!thanks.... helps alot. going to try for 1.25 cubes ported at 32hz using a 4" port.
do you mean GCON? because that is what you won //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifas the title reads.... what are the recommended box specs for a single 10" dcon ported?
No problem //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifit was a long day when i posted this.... yes GCON i meant.
i will be running these off a cadence momentum 5000.1 amp that does 1200.1 @ 1 ohm which i plan to wire the D2 sub down to.No problem //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
? What kind of power are you going to have going to the woofer? If you are running close to rated power you will probably have some port noise. I would opt for a slot port design.
Post install pix. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifgot my amp in.... should start this build this weekend. hopefully it goes pretty quick. rated to awake this gcon.
