ev0le
Which single IDQ10v3 vs. RE audio SE10 is better for SQL from 500 watts RMS 4 ohms?
G5 is rated at 4 ohms DVC, wouldn't I need to run two of these in order for me to get a 4 Ohm load?
Right, Dual 4 ohms can be set at 2 ohm or 8 ohm, single 4 would just put me at two. In order for me to run it at 4ohms with my amp, I need something that is dual 2 ohms, which can be at 1 ohm or 4 ohmsThe G510-44 is dual 4 ohms. The G510-4 is a single 4 ohm.
With your original list of choices, I recommend the G5. It is superior in sound quality than the SE and much greater in output than the IDQ. In a sealed box the SE can't win; ported is another story. I work with both of these woofers almost everyday, not sure how credible I can be.//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
Do you even realize what you're posting (refer to the bold quotation)?Right, Dual 4 ohms can be set at 2 ohm or 8 ohm, single 4 would just put me at two. In order for me to run it at 4ohms with my amp, I need something that is dual 2 ohms, which can be at 1 ohm or 4 ohms
^^^X2, A single 4ohm coil would put you at 4ohms.Do you even realize what you're posting (refer to the bold quotation)?
I didn't see the G5 in the original list of choices? Did I miss something?The G510-44 is dual 4 ohms. The G510-4 is a single 4 ohm.
I was just saying in regards to the original list, not that it was listed. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Sorry for the confusion.I didn't see the G5 in the original list of choices? Did I miss something?
What do you do that allows you to work with both subs daily?The G510-44 is dual 4 ohms. The G510-4 is a single 4 ohm.
Work, customers, trial and error, experience? Being a dealer for both companies can help as well.What do you do that allows you to work with both subs daily?
