I never understood that 1 watt/1 Meter thing....Could someone explain it to me it Laymans Terms? Also, using that what are the Loudest 6.5 Speakers I can Buy? I have Boston Pro 6.4's I want something Louder (I have ~300+ watts to them)
Pro Audio mids can have a sensitivity that approaches 100db @ 1w/1m.Does anyone know the speaker(s) thats have the highest Ratio?
Image Dynamics CD2 Horns 109dB 1w/1m I believe
IIRC 93db....which isn't incredibly high, but is respectable and higher than most.Weren't the ones that Feandil was designing pretty **** high?
However, almost all of those very high sensitivity mids will have very little low frequency extension because they are going to rely mainly on the enclosure to aid them in the low frequency output (by way of ported enclosures, horn loaded, transmission lines, etc). In car audio, with our limited space....this is VERY hard to accomplish. So, it's your choice if you want very high sensitivity with poor low frequency output (i.e. pretty bad midbass output), or moderate sensitivity speakers with good low frequency output (i.e. good midbass output).
Also, sensitivity alone is not going to tell you which will ultimately have the most output. It can give a "theoretical" limit of where the speaker should be output wise with a certain amount of power applied.....but that doesn't take real world affects into account such as power/Bl compression, power handling, etc etc.
If you have 300w per side (even 150w per side) and the Pro's don't have enough output for you....you're either deaf, or there is an issue with the installation or tuning.
So, it's a give and take. You can't base your entire decision off of a single spec...such as sensitivity, otherwise you are going to make a poor decision. And, frankly, applying ample power to even a moderate sensitivity speaker (88db 1w/1m) will provide more than ample output.
What type of kicks? Q-logic? Custom made?Well im no where close to deaf...And I dont see anything that could be wrong with my installation, They're hooked up to my Amp, and they're in Kicks, What could be possibly wrong? My friends system, CDT HD 62's and an MTX amp that puts out like 150x2 sounds louder then mine (I have an SUV he has a Car, would that matter much?)
Would the cone area matter alot? since boston 6.4 are only 6 inches long? I mean my speakers are Loud, but they're not as loud as I would like. The Gain is all setup so there is no Clipping (the amp has a clip meter)
Would z6's be louder?
