Is that right? I'm runnin' it @ 1 ohm now and, on stock elec. It's a Kicker.Nope not nearly enough power, that amp is not stable below 2 ohms and with the sub wired in parallel you will get a 3 ohm load and maybe 500w. They really like 1000-1500
Its not recommended, but my friend has a 750.1 that I found out has been running at 1 ohm for a year with no problems. But then again, its not recommended.Is that right? I'm runnin' it @ 1 ohm now and, on stock elec. It's a Kicker.
Well your going to be running it at .75 ohms, which is not 1 ohm.Is that right? I'm runnin' it @ 1 ohm now and, on stock elec. It's a Kicker.
check hifisoundconnection or sonicelectronix.com as i used to have that amp and paid alot less than that.A new one is available for 400. Could I use my Kicker zx750.1 amp?
