1 mtx 9500 15 " Install Help
purchased a single 9500' 15 " mtx woofer with a ta 810001 mtx amp.... suggestions for install......... amp capable of 1500x1 @ 1 ohm stable........ toyota tacoma extra cab...... not much room to work with... what i can work with 20 " high........50" wide........ 14 " depth...... help me out......
also.... can anyone post some truck install pics or pics that would gimme some suggestions for install...... looking to maximize this woofers capabilities.......
ahh i dont think that amp is 1 ohm stable, prior to the 05/06 line up of amps non of em where. also i dont realy understand what your asking! do u need a box maid or something
The TA810001 is one of the newer amps and yes indeed it is 1ohm stable.
What does the birth sheet say on that amp because I'm really thinkin' about getting one of those.
so what do u guys think.... what kinda install can i go with for a spl setup and can my 15 handle all that power..... or do u recommend a different sub.... i can turn that sub over to a firnd....
no that sub will be fine, it can handle 1000watts, probably even more. also is the sub single or dual vouce coil and as for a box for SPL. give me a min or too
alright. i got 3.6 cu ft net tune to 38Hz. the box is 16 tall 50 wide and 14 deep. maid outta 1" MDF. it has a 14X3.5 port thats 21.75 long. the subs and port would be on the 16X50 peace. and ive factored in for some braces!! anyone else care to try
bigbassboi
Canada
406er
