1 channel amp and 2 speakers
  • Thread starter Brandon
  • Start date
  • Replies 3
  • Views 1K
  • 2
B
Brandon
Guest
I just have a little question. I was wondering if you can hook up 2 speakers to a one 1-channel amp. I was thinking about buying the JBL BP1200.1 amp. If you can, how do you wireit up?
In assuming that the subs are svc 4 ohm, run them in parallel. This can be accomplished by running the positive of the amp to the positive of speaker #1 and then from there to the positive of speaker #2. Same with the negative.
wire the DVC 2 ohms in series to get a 4 ohm from each sub, then wire the subs in parallel to get a final 2 ohm load, resulting in huge bass!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
694
For clarity, why not example 2 ? Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range...
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
Wiring question....using four 4 ohm speakers and one 2 channel amp capable of 2.ohm load... Using 2 ohm stable 2 channel 4 ohm amp to power four...
Guest
SKMexiFry
    May 12, 2024
Brendon Jenness
    May 11, 2024
