1 channel amp and 2 speakers
  • Thread starter Brandon
  • Live activity
  • Replies 3
  • Views 2K
B
Brandon
Guest
I just have a little question. I was wondering if you can hook up 2 speakers to a one 1-channel amp. I was thinking about buying the JBL BP1200.1 amp. If you can, how do you wireit up?
In assuming that the subs are svc 4 ohm, run them in parallel. This can be accomplished by running the positive of the amp to the positive of speaker #1 and then from there to the positive of speaker #2. Same with the negative.
wire the DVC 2 ohms in series to get a 4 ohm from each sub, then wire the subs in parallel to get a final 2 ohm load, resulting in huge bass!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Guest
SKMexiFry
TechGuru88
    Aug 10, 2026
TechGuru88
    Aug 10, 2026
