1/2 din 7, 9, or 11 band EQ. What's good?
Whatever that means. Don't you have another level to beat so you can save the Princess?
whats snuggled up in your ***? Dont i have another level to beat? Ive been beating it so hard the princess is almost there. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Ha ha ha ..... That's about as fuggin funny as it gets ~!!! //content.invisioncic.com/y282845/emoticons/highhorse.gif.6bbb570c3f53dc0dcce8a2b8ad05cf11.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif :laugh:
Here's the dilema .... There is just not very many high end DIN style EQs made .... and the ones that are , are usually full DIN style.
Regardless of you having just bought a new CD player , using the built in EQ is by far your best bet. I just don't personally know about JVC and quality DSP ....
Good Luck !//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
what snuggled up my ***? Good one. lol. I saw your 1up pic and thought I'd make fun. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
lol understood. i was just commenting on blue's salesman like praise on the clarion (or whatever company's) unit. about your question couldnt you find a 30 band eq and just hide it under your seat?
I might be able to do that. Its kinda tight under there. Heated/Power seats have alot of hardware. I think my cousin has a Audiocontrol 3.1. I'll use that to see if it will fit. Appreciate it.
I was going to suggest an Audiocontrol 4.1. Probably the best you're going to find in a half DIN setup.
VERY good suggestion ... I had forgot about that piece. Thinking about it , Eclipse used to make a good 1/2 din that was 7 band parametric ..... I don't remember the model # though ...
Precision Power PAR-650 is another choice .....
here's the info :
Born of the rich heritage of state of the art, competition-grade processors PrecisionPower has always been noted for, the PAR-650 is a semi-parametric ("paragraphic") 5-band equalizer that allows for easy sound adjustment. With variable equalizer frequencies and a variable 2-way crossover, you can master the sound of even the most elaborate multi-amp system. Dual rear inputs, plus a front 3.5mm mini-jack input, allow this EQ to serve as a convenient source selector. The built-in live drivers give your main amplifiers a healthy 6 volts of clean signal and your sub amp a whopping 10 volts of bass fury! When you're not tweaking, the rotary controls can be pushed back into the unit for a flush look. All in all, an advanced offering of signal processing that is "Absolutely State of the Art." Includes installation hardware and 1/2-DIN trim ring.
Features
Pop-out dual-function rotary knobs
5-band equalizer control
Variable EQ band frequency
Variable low-pass subwoofer crossover with level control
Variable high-pass front & rear crossover
Front/rear fader
Dual RCA inputs & front 3.5mm auxiliary input
Adjustable input sensitivity
6-volt front/rear & 10-volt subwoofer output line driver
Blue LED backlight
Includes in-dash trim ring
Specifications
Frequency Response: 20-60,000 Hz
Signal-To-Noise (S/N) Ratio: 100 dB
Total Harmonic Distortion (THD): 0.005%
Output Level: 6 volts RMS front/rear, 10 volts RMS subwoofer
Dimensions: 7" W x 5" D x 1" H (half-DIN)
Shipping Weight: 3 lbs
Warranty: 1 year
Thanks guys. I think I'm gonna look into the eclipse and PPI as suggest by Blue. My radio is suppose to be here today. I'll see how the built in 7 band sounds. If it doesn't please me, I'll be investing in one of these models.
xOld Schoolx
xOld Schoolx
Texas
xOld Schoolx
