1/0 without the big 3
i have 1/0 power and ground and dont have big 3 done. i dont have any dimming or huge voltage drop so i never really cared to hassle with the big 3. i think ill do it eventually
i also didnt install my wire i bought the car with it already wired up.
At a lot of shops it is pretty standard practice to not do the big 3 even if running 0 gauge. But the question is why wouldnt you? It has proven to help and it is pretty easy to do.
see im the type that unless im running a wire to a battery or checking/changing my oil i look at an engine and i got whoa dont wanna touch that i dont wanna break anything.
If you can change your own oil you should be able to do the big 3. There isnt much you can break.
The only time you run into a problem with too big is when you are increasing current into your factory fuse block which is why you run the alternator directly to the battery instead of the fuse box.
Also note your ground or anywhere in the electrical circuit will only be as good as the worst part so it isnt necessarily beneficial to do it half *** but it wont hurt the car.
Yes not doing the whole thing is like kinking a water hose.
Enellz
The Triple O.G.
Enellz
Louisville, KY
rumple4skin
