0g+firewall=lots of broken drill bits....
packerfan
I barrowed a few feet of 0g from a friend so i could drill a hole in my fire wall big enough for it, and it just wont do it. Theres to many wires around where im drilling (easiest place to get to with a drill) Any other ideas as to how i should do this? Run the wire under the car? Im doin 0g+8g.
what kind of drill bit?
alternative might be to drill into the bottom of the floorpan, where it meets the firewall, near the steering column. That's what I did - plenty of room down there.
i had no problem going through the firewall, although the only clear place for me to go through was just to the right of the brake master cylinder. only spot under my dash that wasnt covered with a wiring harness, or have engine/transmission bits on the other side.
not that im trying to piss you off but i bet if u took apart your under dash (on both sides) and pulled down your carpet along your firewall you will find a gromet already there plenty large enough for a 0 guage wire.
Not pissed off because everybody that has a beretta and needs power wire ran to the trunk drills a hole all time. There isnt a gromet anywhere and ive already torn my car apart a few summers ago to do the old 4g power.
y not just enlarge that hole then? its not brain surgery
packerfan
packerfan
Beaver Dam WI
audiolife
RobGMN
    Jun 8, 2026
DEH-P7700MP.mp4
lbn.wrks
    Jun 8, 2026
