Sold 06 Cobalt, Subs, Amp, Box, & Extras
lowrollin70gmc
Zamboni Driver
I'm getting back into construction and modifying my truck's suspension, so I need to haul tools in my trunk along with fabricated truck parts (fuel tanks, ladder bars, etc.), so I would like to remove my system. It takes less room than you'd think, but I need a pass through seat for parts and tools.
Prefer to sell together and local. I'll install for you with purchase.
Car is in Fargo, ND. I also travel I-29 To Sioux Falls, SD. If you're local or along I-29 corridor, I'll come to you for free. If not, we'll talk and I'll probably come for free or near it ($10-$20). PM or contact at 605-376-3130 and leave message.
Specs:
Installed one year, never pushed (I listen to country).
Subwoofers:
Two (2) Infinity Kappa Perfect 10.1s
350W RMS 1400W Max 4ohm Single Voice Coil
Owners Manual
Purchased from Crutchfield - New $149.99 (x2 = $299.98)
Amplifier:
Kenwood 9152D Mono Amplifier
900W RMS (2ohm) 1800W Max
Wired to a 2 ohm load, showing each sub 450W RMS. Gains set to less than 450W RMS to ensure life of sub.
Owner's Manual
Purchased from Crutchfield - New $199.99
Box:
2 CuFt net shared volume. Slot port tuned to 35 Hz. Custom built for Cobalt, and I'll admit it's a very firm fit.
3/4" MDF throughout and 1/4" plywood beauty panel to blend into trunk, carpeted to match.
Also has amplifier mount based on stock Pioneer mounting brackets on inner 1/4 panel.
Extras:
All wiring to stock rear speakers (high level input on amp) and 4 Gauge positive and negative wiring w/ fuse. 12 gauge wiring to subs.
Remote mount bass control and on/off switch mounted below radio/HVAC controls. Includes my panel modified for switches if I get your stock panel.
I also have a black grill made to cover entire enclosure to protect from luggage (covers wheel tub to wheel tub, entirely enclosing subs and port).
$500 installed. If you add up new prices, a custom box, installation, and wiring, subtract because it's used (but in great shape); you've got a deal.
Interested parties can see more info on this page:2 10" subs and photoshoot
lowrollin70gmc
Zamboni Driver
lowrollin70gmc
Fargo, ND & SF, SD
lowrollin70gmc
