04+ dodge and chrysler wiring harnesses
yeah if that headunit can power them fine then id rather do that cause im not really wanting to spend my time and money on amps wiring and new door speakers when i cant complain about sound now. idk how capable a Avic-N3 amp is although to power them.
well you have to options.... you can keep your factory amp running all your speakers (the 160 dollar harness) still get crappy sound from the factory amp....
or you can get the amp bypass harness (40 bucks i think) and run your speaker off the deck and sound much better.....
agreed. forget the harness buy some 9 wire and rewire the output of the factory amp. its in the passanger kick or behind the glove box. time to bea real installer...lol...get your batteries ready...lol
its a pain to pull the amp too. but i would simply just buy the metra amp bypass harness. much easier to do the finding all the speaker wires.
lmao i can get the harness without having to have the headaches ive had in the past with being an installer. but what do you mean get batteries ready?
mine was up in the dash behind the glovebox. might be different on an 06 because its different interior......
oh and here is everything you need for 20 bucks!!!!! even comes with the HU harness....
Metra TurboWires 70-6512 DODGE 2002 - 2004 RAM AMP BYPASS (Infiniti system) - Cartoys.com
**** nice find! from what i can read its going to wire the N3 up normally with its amp powering the speakers now? so all id need is a antenna adapter. im trying to double check before i spend anymoney. i got another 90 to spend on a injector wiring harness :p thanx neel
you wont need batteries to test anything if you get the harness i posted above. you will bypass the factory amp with that harness and use your HU's power.
dye4metal
dye4metal
Tampa, Fl
dye4metal
