03 Police Interceptor (Crown Vic) Wiring
u shouldnt have to drill. there should be a hole in the passenger side floor board to run your run or runs of power. rca's down driver side. power wires and remote wire down passenger side. can ground amp or amps to the flat piece of metal on each side of the trunk before it dips.
This, you can also run your power wire through a factory grommet under the steering wheel on the drivers side as well.
Car is quite easy to wire, even running to the trunk if you remove the rear seat.
TheStolenSystem
TheStolenSystem
Florida
tez4life
