wire amp
  1. Henry H.
    Featured How to maximize my new setup?
    I bought a ported sub box for my 07 f250 crew cab with .7 cuft airspace for each 12"sub (×2). Bought polyfill to make up for the recommended .8cuft for the subs. If I wire the subs together(+ to + ,- to -) and wire that to the amp will I be pushing 2 ohms at 500rms? Or should I wire it a...
  2. D4LL4S_85
    Sun cutting out….
    Okay, first off thanks for taking a few mins to read and possibly help me out… ok so I have 2 fosgate p2s 12s on my 05 Silverado and a 600.1 mono block alpine amp …bought a sundown v2 10 but think I got ripped off on that one …anyways. So I installed my system and when I turn it up to high...
  3. Hags222
    Basic question about calculating RMS and total wattage of my set up
    This question may be quite straight forward, but I cannot find an answer anywhere. I am new to this forum but I found the formula to ballpark estimate my total amperage. I do not understand one part. When you calculate this, do you add up the total RMS of the amplifier AND the subwoofers it will...
  4. D
    How to wire amp and head unit, RCA cable?
    How do I wire the RCA cable with this amp and head unit? Seeing I only have 4 RCA outputs on my head unit and 5 RCA inputs on the amp Amp: MB Quart OA1100.5 Head Unit: Pioneer DEH-X3600UI Sorry for this newbie question
  5. F
    Wire my 5 Channel Fosgate amp??
    I have a Rockford Fosgate Prime R600-5 Amplifier and I am wondering how to wire up my 2 Rockford Fosgate Prime R1s412 subwoofers and my Kicker CS65 100 watt speakers as well as some 30 watt pioneer speakers. Need Help ASAP! Thanks!
  6. B
    4 sub's, having a problem with 2
    I have four kicker comps on 2 900 watt 2 channel amps. I have them split off one power wire with a dist block. Two of them work fine on one of the amps. On the second amp, when one sub is connected, that one sub works fine but when I hook up the second sub on the second amp, both subs move but...
  7. J
    help needed
    So i hooked up my subs and amp and everything is right But my amp wont turn on. Ice checked the Remote wire and Its in the right place. Is there abother Way I could wire it to a fuse or something so then it will turn on?
  8. MellowHype
    What Wire To Use?
    So ive currently got an Alpine MRP - F600 powering one pair of Alpine SPR 60c, at 100wRms. Using 8 awg wire. Im going to be getting a Type R 12inch running at 2ohms at 700 watt rms powerd by Kicker EX1000.1 I was just wondering if 4 awg wire would be enough for the Kicker? or will i need 0 awg...
